Hello I'm once again after some advice my 1.9 tdi needs a new o/s driveshaft seal and on the vag.com it says you have to remove the entire d/s my question is can you not just un do the lower balljoint so when the splined bolts are un done you can just.move the d/s out of the way
Also the size of the spline bit and what type of oil is correct for this box cheers in advance
