Drivers xenon beam not working...
H8T WP
Very strange. It has jUst stopped working. It's been working all day, but very wet weather. Looks like some water on the inside of the lens. Should dealer sort ?
H8T WP
Will do pum. Strange as you saw it's been fine all day :s it's standard oem xenon.
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
if you search i think that there are a few psots with people who have had 1 or both of their xenon lights that have failed.
what i think TAM was saying was that the xenon fillament is covered under warranty so even if this part is at fault it will be replaced.
always seems to happen in winter just when u need them most , bet if it was summer it would be ok :shrug:
Jan 18, 2007
518
West Of London
all fixed, they replaced the unit and job done :) thats all i needed to know , all workin and done under warantee
I would ask what would happen if the car is out of warranty. Replacement of the unit could be very costly if it is not covered under some lifetime guarantee arrangement.
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
You could say the same about a gearbox .. or an engine though ... you dont start asking for lifetime guarantees on them now do you? :rolleyes:
Jan 18, 2007
518
West Of London
The point was that if it was due to some ingress on a failed seal, every week when you check the oil / water etc, you run your eye over the part of the headlight which H8T WP was advised had an issue with, just to make sure you do not do the same thing.
More as a preventative measure than quibbling about warranty covered replacements.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Just for your info, Xenon/HID's do not have filaments. They have 2 electrodes and a spark that jumps between them :D
Can you tell I'm boared...........
