Drive shaft nut socket size
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Anyone know what size socket is needed to remove the drive shaft nut?
This is the bolt
dholdi
931
Preston
If its the same as the Leon its 30mm, obviously multipoint socket rather than hex.
PS - thats a nut ;)
mjrally
If your looking at taking the drive shaft off, ideally when re-fitting you need a new nut, as they have a bent in tang that prevents the nut from loosening. this snaps of when remove the nut, so wont do its job if you put the same nut back on.
