DPF removal, no mapping required?
Mar 13, 2008
672
Suffolk
I was told it would be best to get my DPF gutted.
They said I shouldn't need it mapping out if its all stripped out as the pressure should stay constaint.
Is there truth to this?
Speed-FReek
1,109
17
South Oxfordshire, UK
You may get away without a remap although it's not really recommended. However, what you definitely would need is the ECU reconfigured so that its no longer expecting the presence of a DPF (i.e. the soot load monitoring and regeneration functionality etc.).
However, if you're going to the trouble of getting the DPF removed/gutted then you would be best advised to take it to a place that specialises in doing a DPF delete and remap as a single package.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
Who told you this?
Mar 13, 2008
672
Suffolk
Independent VAG garage.
He said it might need doing, if so he can out me in contact with somebody who can do the DPF map, and a remap aswell.
Luke
Mar 13, 2008
672
Suffolk
To add, as mine is the first year for the Leon to have a DPF a fitted it should be fine to remove and no map required.
I have seen a couple of members here to have the DPF fully removed and pipe fitted, and no mapping required.
Luke
bilton17
31
www.facebook.com
Hi i know this was a while ago im in oxfordshire and looking to have my dpf removed did you get this done in the end and if may i ask where thanks in advance
Sent from my SM-G920F using Tapatalk
shanepaul88
Nottingham, UK
Does anyone know what the crack is with m.o.t now with this, as I know that if it has been removed it's a straight fail, but obviously it's only a visual check. Or so I've read through research.
Thanks!
bilton17
31
www.facebook.com
I spoke to my local garage it is just a visual check obviously they see its been tampered with it will fail then they do a visual smoke test
shanepaul88
Nottingham, UK
Yeah I thought as much, I really want to get it done the only thing putting me off was obviously the whole M.O.T side of it as I wouldn't have money to mess about with putting it back to standard if it did fail due to mortgage etc etc etc
