Doors won't lock/unlock!!!
JPM
Just walked up to my Leon and pressed the button on the key to unlock and nothing happened! I ended up having to put my key in the door (old school) to get in. Also, the Mrs had to climb over the drivers seat to get in!
Funny thing is that the remote locking still unlocks/locks the boot and turns the alarm on/off, but not the doors. I can hear a solonoid clicking so it sounds like the key is not at fault. Also the unlock/lock button near the electric window controls fails to do anything.
Perhaps a fuse has gone? By the way - it's been raining a fair bit today and i did have some water under the door so wonder if that's something to do with it?
Any ideas/help on what might be at fault would be greatly appreciated. Thanks very much.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
After reading a few similar recent posts on here I would try a ecu reset. Disconnect the negative battery terminal for 20-30 mins and reconnect.
JPM
Thanks for that, i'll give it a go tonight. I didn't have much luck with a search - i'll try that again as well.
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
JPM sounds like your Convenience Unit has gone. This happened on my old 110tdi! Has other things stopped working such as interior lights when you open the door?
Cost me £400 quid to get it replaced :(
JPM
Everything else works fine. I hope it's not that Unit... £400... aaarrrggghhh!!!!
WeeJase
pert
Jun 2, 2001
8,595
BEFORE you spend 400 quid,listen to me.
find your conveience unit(OCATVIA VRS is up under the dash near the steering wheel)take it out,find the part number and go find one on e-bay or a scrappy. find someone with vag -com and get them to recode your key(s) to the new(er) unit.there are many many different cars for the unit.
i paid 30 quid for a unit,and ended up going to skoda for a re-code(didn't know it had to be re-coded) so i apid more than i would have liked,but FAR less than skoda would have charged for a new unit.
i am happy if i have to replace mine again and again now i know how to. please don't go to your dealer if you can use a screw driver/laptop.
i'll show you pics when i get home of my vrs's unit ;)
JPM
That'd be great thanks WeeJase. I only ever visit the stealer at last resort so i'll defo look into what you suggest. Some pictures would be much appreciated, thanks!
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
If it helps (which i would imagin it dont) im suffering with the same problem, is a thread on here some where but it just got burried. sometimes drivers unlocks, some times it dont, some times passanger opens sometimes it dont?!?
JPM
Just went down to Jabba Sport who kindly ran a vag -com diagnostics test. The test show zero faults!!! They recommended going to a auto electrical specialist to try and fault find. Sounds like this might be a difficult one to solve so any suggestions are really appreciated.
Thanks.
WeeJase
pert
Jun 2, 2001
8,595
i started by removing door cards and looking for signs of water ingress,check plugs for corroded connections,replaced or cleaned fuse blades.
i did find early on the central locking control unit fuse,took this out and when i replaced it after a clean,it kinda reset itself.but mine HAD shown a fault code to begin with.
oh and btw can't you just open the mrs door from the drivers side?doesn't it release the door when you lean across and pull the handle? :D
edit: fuse F6 in the octavia vrs 3rd row along from the left 3rd from top
JPM
Thanks for the extra info WeeJase. I got the bottom half of the door card off this evening and then couldn't figure out how to get it off completely! I'll have another go in the morning.
No I can't open any doors from the inside or out other than the drivers - it's a right pain in the arse!!!
WeeJase
pert
Jun 2, 2001
8,595
thats an mot failure on its own mate.
if its like the octy the door handles hold 3 very secure screws that go through to the door itself the handles have a front facia,takes a bit of feeling about
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Excellent advise, wish i got this 2 years ago :)
JPM
The issue turned out to be a blown fuse after all, which was good news as it only cost a few quid. I had tried changing the fuse before it went to the garage, but apparently you need to reset the central locking (involves a sequence of key turns and button presses) after changing the fuse to get it to work again.
I'm just glad it wasn't the expensive control unit!!!
WeeJase
pert
Jun 2, 2001
8,595
you jammy sod :D
glad it's sorted
