es_one
hi guys!
My driver side door wont open from the outside,only from the inside..so I think there are problems with the doorlock,the lock down at the door that keep the door shutt`d..
Does anyone know If I can use a doorlock from vw polo?
when you say it wont open do you mean that it wont unlock or you cant open it if its unlocked?
Whip the handle off and have a look, its just one allen key bolt.
The lock assy has fallen off mine and into the door [:@]
I have demounted the doorhandle,doorlock and everything inside..
No problem with the doorhandle,but when I try to use the doorhandle from the outside nothing Is happening in the "doorlock" down at the end of the door..so the problem is there..
So I think I need a new "doorlocker"
