I have just flushed, refilled and bled the brake fluid after replacing discs and pads, but still (as before) have a little bit of pedal travel before brakes bite, which I just don't get.
When I did the flush I didn't have engine running, just did normal pump pedal when valve open, close valve before pedal up, keeping resevoir topped up.
I have been researching here and elsewhere, and see vag-com can cycle the ABS, which I guess might help me.
I see from Ross-Tech that to do the bleed cycle all wheels must be off the ground - is that it? Any opening of valves or anything, or do I just need to check on brake fluid level after cycle?
