mattstead
Hi, Just done the first trackday in the 16v ibiza, all went very well, but upon pulling into the pits there was a distinct haze of blue oil smoke coming from under the bonnet. It certainly wasn't a major oil leak, but rather a small bit landing on the hot exhaust - i.e at the rear of the engine. The engine was very, very, slightly over full at the start of the event.
Has anyone got any ideas as to any possible areas to look at for a leak? is the rocker cover prone to it?
Also, as this has only happened on a track I was wondering if it was due to increased crank case pressure? perhaps I need an oil catch tank instead of the recirculation valve thing? The oil temp was up to 112 degrees on the track (normally 90 on the road), is it possible it's thinning out a bit and finding any weakpoints with Gaskets? Would anyone reccomend 5-50 oil for trackdays with this engine or just rely on decent fully synthetic 5-40?
Many thanks.
Matt.
Many thanks.
Matt.
