Hi, Just done a DIY heater matrix swap on my 2.0TDI FR (usual problem of gummed up matrix causing coolant loss and poor heat out of some vents).
I'll post some pics/info about that later this weekend..
However finished putting it all back together and just as I was about to celebrate no leaks I realised the stereo wasn't switching on, an airbag warning came up on the dashboard and the vent lights are not working..
Have I been daft* - I didn't remove the battery ground terminal doing the heater matrix replacement - blown fuse or perhaps something worse?
At least I have hot air coming out of the vents (which won't be useful for a few months unlike the stereo!!) - doh!
Drives ok and coolant gradually stabilising in level as the air bleeds out of the system - likely to be topping it up for a few drives.
*Edit: yes, I had been daft and badly reconnected the glovebox head unit!
