DIY hardwire dashcam installation
kevster184
686
29
Some say it can be interference from the cable, if it helps one in the front of mine is tiny/cheap/thin cable which powers a Mini 0805 the other is much thicker that came with the A119 camera. Very much like the Nextbase power supply quailty.
mrtnbcky
hi all iv already got a front dash cam hardwired in. I'm going to replace it and get a new one that has front and back cams. my questions has anyone hardwired a rear cam in, where did they run the wire for the rear cam and where have they placed the cam on the rear windscreen?
I found this thread while looking for inspiration having had a few issues installing a hardwire kit for powering a NextBase DAB adapter (which works absolutely brilliantly by the way, despite the reviews its got on Halfords' website) in my Mrs's car, albeit a bit messy with all the cables, hence the hardwire kit.
Anyway, I just wanted to mention that I use a NextBase Duo in my car and the rear view camera pokes out from behind the rear view mirror and with a tighter angle lens than the front camera captures really good footage of what's going on behind me, while the wide angle front facing camera captures the view at the business end.
weasley
137
South Oxfordshire
Yeah, I intend to get a different hardwire kit - just using a generic Chinese one which was fine in my Yeti but this didn’t have DAB. I also don’t like that it has a low voltage cutout, presumably to prevent draining the battery if left live but the low voltage limit is obviously set a bit too high as it cuts out every time the engine starts. I have wired it to an ignition-control fuse which I know stays live; this all happened in the Yeti too but that didn’t have stop-start so was less of an issue.
nokiauk
524
25
Edinburgh
Fitted my dashcam (Nextbase) however when removing the top section of the A pillar trim to route the cable all the clips came out, is there an easy way of putting them all back, doesn't seem to want to clip into place
RADIOTWO
516
98
North Derbyshire
nokiauk
524
25
Edinburgh
Thanks yes they are the metal type, I suspect 1or 2 have been bent so I may have to remove the panel and straighten them out and try again.
R4CK5
609
85
I didn't even need to remove the pillars to get the wires in, just tucked them in with a trim removal tool.
Proby
I Luv Boost!!
Aug 17, 2009
98
Just want to say thanks to OP for this thread. Fitted a Smart Witness 1080p camera yesterday. Managed to hide all wiring, I actually pulled the A-Pillar trim off as was easier to hide cable.
Dave77
19
I need to fit a dashcam in a 2017 facelift Leon, what fuse should I be piggy-backing for it to be only on with ignition?
kevster184
686
29
Hi Dave,
It looks like you are new here, so welcome.
Take a look at the this thread starting on page 1, second picture. That should be your answer assuming nothings changed. Compare to your car if so let us know if not.
15 pages seems a lot but most of the time on these forums the answer is often in there. ☺
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
I haven't got a 2017 leon but my guess would be the 12v cigarette lighter socket for ignition switched source. The fuse number should be the in owners manual.
R4CK5
609
85
I've got a 2017 and I used the yellow fuse shown in the second picture of post number 1 of this thread.
Sent from my SM-G950F using Tapatalk
Speedbird
268
135
Big thanks for TerryT for the guide on page 1.
Just installed a Nextbase 212 tonight with the Nextbase hardwire kit.
Took me about 2 hours as I am a perfectionist, but it is exactly as the guide says on page 1, and it all works spot on. Absolutely no exposed wires other than where it exits the headlining.
Only thing is, the Nextbase cam is quite bulky. So in the future I may get a Blackvue or maybe a Mini 0906, providing it works with the installed NB hardwire kit.
Speedbird
268
135
Some pictures of my install this evening
R4CK5
609
85
I managed to get my NB212 tucked up behind the mirror. Sticks out a tiny bit at the bottom and a little at the side but still well hidden.
Does yours rattle over bumps? The actual base where the cam connects rattles on mine and it's starting to do my head in
Speedbird
268
135
I did consider mounting mine behind the mirror, and actually bought a stealth mount from ebay so it would be a smaller setup, but then decided if I want to take the camera off, the rear view mirror would be in the way.
Do people generally leave the cam in their car permanently?
Just been for a test drive and no rattling. Can you return the mount and exchange it for a new one?
