Disconnecting vs Disabling EGR?.
Mar 13, 2008
672
Suffolk
Was browsing the forum last night and spotted somebody who has disabled the EGR via VAG-COM. Now i have disconnected and plug the tube on the EGR, But does disabling it make any diffrents with VAG-COM.
Thanks.
Luke
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
With Vag com you reduce the amount of recirculated gas the engine is expecting, just removing the vac pipe will eventually bring on the engine management light. You can buy removal pipes and have the ecu software adapted (normally when remapped) to adjust to the change, thus removing the egr control side of things.
Mar 13, 2008
672
Suffolk
They vac pipe has been off for nearly a year now. Would disabling the EGR via VAG-COM be any noticble diffrence?.
Luke
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
no mate, none what so ever, with the vac pipe disconnected the egr valve has no way of opening. I'm suprised its not flagged up a fault, is it definatly the egr valve you have disconnected and not the anti-shudder valve?
muddyboots
Still hanging around
Oct 16, 2002
5,739
Earlier ECUs don't flag up a fault if you block off the vacuum supply to the EGR :)
Mar 13, 2008
672
Suffolk
Yes it the vac pipe on the EGR, She still smooth when turning the engine off. Mine is a late 2002 car.
Luke
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The reason for this is the earlier models (DIESELS BUILT BEFORE 2004 AND PETROLS BEFORE 2001) dont have OBD or EOBD which means if a fault occurs which effect the emmisions then the vehicle must display a warning sign in the form of the engine light, or OBD light.
I dare say that an egr reulation limit fault will be logged on the ecu but will not cause the light to come on.
