Disabled dashboard indicator lights
rf860
3,575
scotland
Really interested in this as well cos mine has the same thing! Started to wonder if it cos i dont have a high spec model :cry:
Ferryman
1.8T Goes Like Hell
Oct 23, 2008
208
Helsinki, Finland
The instrument cluster supports many sensors which are not connected or installed in Ibiza.
For example Ibiza is lacking the sensor needed for the "fasten seatbelt" warning light.
Some of the sensors are connected to the central convenience module, but not to the instrument cluster.
The VDO instrument cluster installed in Ibiza supports following gauges and sensors:
- Sidelights and dip beam
- Power steering
- Left turn indicator
- Coolant temperature gauge
- Ignition lock
- Main beam
- Fuel reserves
- Fuel gauge
- Right turn indicator
- EOBD (Check Engine)
- ESP
- ABS
- Hand brake, brake fluid level too low
- Airbag
- Safety belt
- Tailgate open
- Worn brake pads
- Windscreen washer fluid level
- Driver's side door open
- Oil pressure too low
- Trailer indicator
- E-Gas
- CCS
- Alternator charge control
There is also another variant of the instrument cluster which has additional two gauges: oil temperature gauge and battery charge gauge.
