disable no seatbelt warning
jsab500
I did a search and couldn't see anything, sorry if i missed the answer.
(For a 10 reg ibiza fr 2.0 tdi)
Is there any way to disable the no seatbelt warning? It is extremely irritating when I've got a heavy bag on the passenger seat and it wants me to fasten the seatbelt, and also if i'm doing something like moving the car in the driveway and this noise goes off...
It didn't seem to be connected to one of the easily removable fuses unfortunately.
Thanks very much,
James
DEAN0
Old Git
Feb 1, 2006
5,419
Preston - UK
Thanks very much,
James
I am sure this can only be done using VCDS ( VAG-COM ) on the MK5.
The local stealer has an FR TDi in and they only see the light on the dash rather than the silly beep beep beep ! so it can be done.
Unofficially i read somewhere that you can unplug the seatbelt sensor and bridge it so it thinks the belt is always fastened.
J400uk
1,978
London, UK
Just leave it on, its a safety feature not designed to be turned off. It shouldn't sound when your moving the car on the drive, if it does your going too fast.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
plug the seatbelt in then?
around the 'heavy' bag or behind it, either way it's quicker easier and safer then disabling it.
Elliot29
379
Yer I done it to mine with VCDS to see if I could haha, turned it straight back on though :p
alex13p
∫℮ª↑ ©ч‽Яд
Jan 17, 2011
426
Fleet, Hampshire
Got a point here, it only goes off if your moving over 10-15mph, why would you be going faster than this on your drive?!
jsab500
Thank you ibizaracebrake, adamb87, DEAN0, and Elliot29 for your responses
