Disable Clifford Alarm?
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Just bought a car with a Clifford Concept 500 alarm system fitted. Thing is i don't like it and i dont want it on there (because the dam thing keeps going off). The car (2001 Ibiza Cupra) has its own alarm system which i would rather use.
I want to know if it is possible to completely dissable the clifford at all?
The alarm does have an override feature which works by tapping in a code, but............ it enables its self again after you start the car :rolleyes:
Failing that, anyone know any local ish Clifford dealers in Gloucestershire?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
easy way is to put it to "valet mode ) every time u exit the car , think u press the left 2 buttons on the remote , n the led stays constantly on , tho every thief would know that ur system is deactivated , plus it will need doing eery time u stat the car , u will need a clifford dealer to deactivate it tho fully
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Thing is valet mode is also playing up :( I think one of the sensors maybe faulty, the alarm keeps acting like one of the doors isnt shut properly :(
Hmmmm looks like im on a mission to find my nearest dealer then. Thanks for the info matey :)
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
I do mate yeah, ive got a 'master' remote (5 buttons) and a 'companion' remote (4 buttons).
Basically what keeps hapening is this:
Everytime i go to lock the car, the alarm just sounds constantly, so i press the arm/disarm button again, and the same thing happens. I've only just bought the car tonight and it happened when i met the guy to pick it up. He said it only ever happened once before (he sorted it by entering the 4 digit code via the PlainView switch) but i've tried that and it isnt helping :(
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
is the bonnet, boot closed . u can use a feature called total event recall , start the car and the led will blink repeatedly then pause a bit , then blink again . pause blink , etc 4 ten repetitions , count the blinks between pauses , tell me how many blinks , il tell ya wats wrong
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
1 flash between pauses= activation of proximity sensor
2 tilt.motion sensor
4 door ajar
5 boot/bonnet ajar
6 bonnet(only if u have intellistart
7 ignition armed whilst activated
8 3 incorrect valet codes inputted
10 power tampering or battery is low
hope this helps
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Sods law mate, its working ok now. Would you mind PM'ing me your email address and i'll contact you tomorrow as i'm sure it'll play up in the morning? :)
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
4 door ajar
5 boot/bonnet ajar
hope this helps
Thanks mate, that'll help... cheers :)
