Dip Stick Removal
MAR4973
8
8
Hi
Is there a knack to removing the oil dip stick . Tried today but it’s locked in and looks like it’s got a clip on it so can’t be pulled out .
any ideas ?
thanks
M
MAR4973
8
8
Like in this photo . Don’t want to pull out and snap the tabs . Is there a way to do it ?
CosmicBlue
Enjoying retirement
Nov 25, 2023
121
87
Warwick, UK
Just came looking for the same answer for my newly acquired '23 Ateca - I can see the yellow stick has little 'claws', they are very reluctant to give up!
One just has to be rough with it then?
Reactions: jcbmally
Karbonfaiba
184
115
Hampshire, UK
I just checked my oil level and quality - yes - you just pull directly upwards with some force. If you are really concerned about it, you could apply some pry action on 1 side of the clip with a finger, while pulling up with the other hand, but it's fine.
What I struggle with a bit is making sure to grab the other end (with a tissue) lower down the stick just before you pull it all the way out - so it doesn't flick oil over yourself or the windscreen. Then making sure no lint goes on the dipstick after you wipe it (although this will be collected by the filter).
Villabrand
117
55
I found out on my formentor that the dip stick does go in a particular way round so make sure you get it the right way. Easy trial and error as it is easier to put back in one way than the other
Reactions: jcbmally
