Model Year 24/25 Dip stick MY2025 1.5 tsi
Rainman
68
9
I just purchased a Cupra formentor 1.5 tsi 2025 MY….i was searching for the dip stick to check oil levels ..didn’t managed to find it ..never the less I only managed to check oil levels through central infotainment system …is this the only way or it’s me that’s blind and I can’t locate the dip stick ..
the_winner
39
11
33
Athens,Greece
Rainman
68
9
Thanks for the reply the_winner but it’s not like this the 2025 MY ( as in your pic)
Spivvy
287
138
UK
Where is it in the info system , wish screen was it under
Sent from my Pixel 8 Pro using Tapatalk
Rainman
68
9
If you go to the car app from there at car status … it has an option check oil levels … it shows a virtual dip stick with your engine oil measurement
Reactions: Spivvy
the_winner
39
11
33
Athens,Greece
I am sure that the engine is the same with the previous one , so you can add a new genuine dipstick that you can buy from the dealer . Like audis…
Rainman
68
9
I a, not sure you can do it …as doesn’t seems to have by design ….what it needs as you may see in the picture of the engine bay above ..
the_winner
39
11
33
Athens,Greece
I see the picture, somewhere at the cylinder head you will find a plug , if you remove the plug you can install dip stick . In Audi and BMW is like I told you , with plug .
your engine is the same with the pre facelift model which has dip stick .
Rainman
68
9
Thanks I will ask about it at the dealership
the_winner
39
11
33
Athens,Greece
ok i double check it from VW ETKA program ,
Your engine use this plug with part no: 04E115418B they have this plug at the hole where the dipstick goes.
You can install the dipstick with part no 05E115611B
Reactions: Freddy
