I tried to remove a front wheel on my 19 Mk 3 today. It would not come off after the bolts were removed it was stuck solid. In the end I hammered a screwdriver down the single slot gap at the back of the alloy wheel and it came off with a crack. I greased the hub centre before refitting the wheel.
Upon inspection the rusty steel hub centre had corroded to alloy wheel centre. I would presume this is the result of galvanic corrosion of two dissimilar metals, iron and aluminium in the presence of a dirty water electrolyte. I have added a slim screwdriver and hammer to the boot toolkit.
Although the car is over 4 years old the front wheels were removed under 2 years ago to replace the badly cracked Dunlop Sport Max tyres.
Just a note of caution !
