Paul Smith
216
19
Hi
When putting injectors in with new seals is a must but is there any angles or degrees or adjustment needed for them to work correctly?
Or are they just a drop in and go part?
Some are drop in and go and some need coding in to the ecu as not done any on a Vag engine but have on other makes the coding in is simple it just a case off writing the number off the injectors down on a bit off paper and the cyc number and going into the settings on a computer that’s plugged into the ecu and typing them in
I think it would be or a snap on machine only if fitting new or second hand ones
If your putting the original ones back in just put them in the same place as where they came out and it wouldn’t need coding in
Ok cool, providing these are the originals for this engine lol. It had an engine swap and I don't know if they used other injectors or mine from the other lump
