Diesel drivers: watch out for waxing, says IAM
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
just thought as the cold weather is here this maybe usefull for some
http://www.iam.org.uk/latest_news/
pasted the bit below
FOR IMMEDIATE RELEASE
6 January 2010
With -20°C forecast in some parts of the UK, the IAM (Institute of Advanced Motorists) is warning drivers of diesel cars to remember that their fuel can wax over in extremely low temperatures, which could damage the fuel filter and cause a breakdown.
Neil Greig, IAM Head of Policy and Research, said: "Waxing is the formation of crystals in the diesel which block the filter. If you drive a diesel vehicle, it pays to try and park in a garage or sheltered area, and try to not to leave your vehicle standing unused for too long,"
"If you can’t park in a garage, do ensure that the engine bay of the car is parked downwind, so that the wind hits the back of the vehicle first. After starting the engine, let it idle for 10 minutes before driving off, as this will let the heat from the engine warm the filter and pipes."
Lorries with exposed fuel tanks and fuel pipes are most at risk but cars and vans can also be affected if it’s cold enough.
Water in diesel fuel tanks and filters can also freeze. Mr Greig advised: "Keep the fuel tank full and, if possible, fill it before arriving at home as this will prevent the build up of condensation on the inside walls of the tank, helping prevent water building up in the bottom of the tank."
Notes to Editors:
• Oil Companies supply winter diesel fuel that can withstand temperatures down to -15°C from October to March.
• Filling stations sell fuel protected down to -15°C in winter. Additives are available but they should be mixed with the fuel before it gets cold, not after. They may also affect the warranty on the engine.
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Very interesting and thanks andrew for the post.
Always let the car warm up for a good 10-20 minutes before I set off. So important for the oil to heat up and obviously the fuel now.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The TDI engines have a valve in the fuel filter that opens in the cold to divert excess pumped fuel coming back from the engine straight into the filter, to warm it up faster. That obviously helps prevent the filter getting blocked with wax.
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Handbook states that it is equipped with a fuel filter pre heater as mentioned above, that keeps system operational down to approx minus 24 degrees. Seeing as the coldest ever uk temp was minus 27, im not worrying too much.
air121005
1,609
Worcestershire
i knew diesel froze but thought it was nearer -30....top info Andy :thumbup:
i think if it drops to -20 i may be inclined to stay in the house anyway to be honest! :lol:
joesmad4it
Cupra TD-aight!
Mar 11, 2008
229
Wickford - Essex
Thanks for the advice very interesting! I have heard that running the car on 'cold oil' (letting it idle for ages and not reving it) causes as much damage as driving without properly warming it up?! Is this un-true as I can't see how making the engine work harder with the same cold oil will help apart from warm it up quicker :shrug:
Andrewcupra TDI
Apr 30, 2008
3,282
not by the looks , just got this send round via work (safety minded )
but these details are by the institute of advance driving/motoring , not linked to my work
so god knows
i do know i had diesel stored out my back a year or so ago , and what was left in that had froze so makes you wonder dont it
volvic
It's just water
Jun 28, 2008
791
House of Batiatus
Leave it 10mins before setting off? I can't see that helping as after 40mins of driving my temp gauge has just reached 60(that's in minus conditions) surely driving it soon as it's started will get it to the operating temp quickest?
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Yep these diesels just don't warm up in the cold. A minute or two to circulate oil is good, but idling an engine that just doesnt warm up isnt good. If your car isn't reaching temperature after 40 minutes of driving i would block off maybe a 1/3 of your radiator to make the car heat up to 90 quicker.
volvic
It's just water
Jun 28, 2008
791
House of Batiatus
That's a a good point. You a black cab driver by any chance? Many of them do this to save fuel as it gets to operating temp quickly.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Nope, my motorbike had an optional extra radiator guard for cold weather from new. Leaving to idle is never good for an engine that isn't designed to do it. Im going to be blocking off a bit of my rad tommorow as whenver cruising at 60 and putting the heating on the temp drops away from 90 rapidly.
Jan 22, 2007
2,074
some may say lala land....
speaking with colleague about it yesterday he said it will happen more often than likely if you let tank get low.
i normally said i fill at the beep, and he said yep you'll get it. fill sooner, say half or 3/4 used will also reduce it.
