grayham
Hi all, I'm in a slight pickle! Sorry if this is a bit waffly, but...
A couple of weeks ago my CEL came on - first time ever, didn't even know what it was. So I took it to the nearest VAG dealer (VW dealer in Ruislip) sharpish, in case it was something serious. They charged me £65 to plug their laptop in and read out the fault codes! Anyway, turned out to be 17705 and 17545. They quoted me ~£300 to fix it, by cleaning the throttle body and replacing the MAF.
17545 P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17705 P1297 Connection turbocharger - throttle valve pressure hose
I then started searching around on here and elsewhere, bought VAGCOM and a lead, and started logging things. Looks to me like the MAF is fine. My car is a stock 2001 Cupra (AUQ), and I'm getting up to 158g/s on the airflow reading, which sounds like it's OK to me, unless there's a very intermittant fault that I'm just no capturing. Plots of it look fine - no unexplained jumping around.
So currently my uneducated money is on either a dodgy DV, an air leak somewhere, or a dodgy pre-cat O2 sensor. Logging the O2 sensor shows it jumping about a fair bit, and spending a lot of time below the -10% normal threshold, but I don't know if that's because the sensor is knackered or because something else is causing the O2 levels to go outside the normal range.
So I've taken the DV out, and taken a good look at it. Thing is, I can't get the top off to check the diaphragm. The bugger is on very tightly indeed - if I try any harder then I'm sure to just crack it. I've even filed a couple of little flat spots on it to get purchse in a vice. I read somewhere that you should be able to push the diaphragm up, seal the top hole with your hand and see if it returns or stays up, but having poked around in the bottom hole, I can't get anything to move at all. I've not seen inside, so am not 100% of how it's supposed to work.
Can anybody give me any further clues as to how best to proceed? I cleared the fault codes when I first got VAG-COM, to see how quickly they came back, and the fuel trim parameters haven't yet drifted back out of range. Not sure how quickly the adaptation should take place.
Cheers,
Gray
Cheers,
Gray
