derv filter
pedro-tdi
hey all guna change my derv filter on my pd130 sport, seems straight forward enuff bt my mate says 2 fill the new filter with diesel b4 i start it so it wont b dry, any truth 2 this and any pointeres wud b appreciated. thanks.
Deleted member 13581
Always fill the new filter with diesel to the brim or there will be air locks in the fuel system and register a fault code due to low fuel pressure on the sensor.
Worse case is the engine doesnt start.
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
as said fill the filter, i normally drain the fuel out of the old filter to do this. just turn the little valve at the bottom
JR_130
127
and after fitting the new filter, you can turn your ignition on and off a few times (activates the pump from the fuel tank, and the system should self bleed)
st10587
Oct 4, 2007
3,669
Hindhead
the last one i did like that took ages to get enough fuel into the filter to be able to start the car
Mar 16, 2008
692
Wiltshire / Bristol
I never bother doing that. Just turn the ignition on for 30 seconds, then start the engine. It will run for a few seconds and then cutout. Turn the engine over again and it will fire up after a few secs, job done.
Dont use the diesel from the old filter as it will have all the water, muck and crap that the old one filterd out in it!
I fill up a small can of diesel before i do my service and use the fresh diesel in that for the filter. The rest gets put in the car when im finished. :lol:
conkerman
136
Don't bother messing about, the transfer pump fills it in no time. I have done about 10 filter changes and never bothered..
Conks
