hey all guna change my derv filter on my pd130 sport, seems straight forward enuff bt my mate says 2 fill the new filter with diesel b4 i start it so it wont b dry, any truth 2 this and any pointeres wud b appreciated. thanks.
Always fill the new filter with diesel to the brim or there will be air locks in the fuel system and register a fault code due to low fuel pressure on the sensor.
and after fitting the new filter, you can turn your ignition on and off a few times (activates the pump from the fuel tank, and the system should self bleed)
I never bother doing that. Just turn the ignition on for 30 seconds, then start the engine. It will run for a few seconds and then cutout. Turn the engine over again and it will fire up after a few secs, job done.
Dont use the diesel from the old filter as it will have all the water, muck and crap that the old one filterd out in it!
