The product selection for just the paintwork alone. This does not include what I used on the wheels, plastic and rubber trim and glass...
First started off with the pre wash using valet pro snow foam mixed about 30-100 with water to
help lift the majority of the muck on the car before blasting off with the hose.
Then once blasted off...
Next was a complete detox shampoo using G3 detox shampoo. And once dry....
Once all of the surface crap was gone it was time to get the crap out of the paint and also the hard to shift surface stuff. Using auto finesse oblitarate got the tough tar off the wheels and lower bodywork before using iron x to bleed all of the toxins bedded into the paint and wheels. Before....
It's hard to see on the after without zooming in and the black paint makes it hard to see also but there was results. Not as much crap as I thought but then the car is well maintained
After.....
Once rubbed in thoroughly after dwell time it was blasted off. Next was for the clay. Bilt hamber auto clay soft folmula using water as lube. Had never used this before so was worried about the paint but excited to see the results. New clay...
Bearing in mind all the prep work so far you would think the paint was clean? Think again.....
Now the paint is stripped back it still looks good from a distance....
And up close too lol
That's all of the prep work done so now onto the protect and seal. This was done using auto glym high resin polish...
Then sealed with colinite wax. Now she was looking and feeling hot!!
Now the finishing touches was to tidy up the plastic trims with auto glym trim gel. Two tone example after and before on the splitter....
The wheels were sealed with colinite, tyres dressed with auto glym dressing, and glass polished with auto glym glass polish. And there she was done...
That's the outside done till spring. The inside will be tomorrow. Thanks for you time and hope t was a good read or even helpful for some.
