Got another present today
Trackslag charge pipe
Old verses the new. Most noticeable is the lack of silicone elbow now and just a small coupler. Lovely piece of machinery and welding really impressed with the finish.
Much smoother lines and does away with the dink on the underside near to the corner of the rocker cover.
Also half inch bigger diameter.
Stage 2 mk1 LCR 291bhp AmD tuned.
Hi bud. Your car is given lots of ideas. Done the led reverse lights. Wow what a difference. Now i want to do interior ambient light.
Any chance of a link for them because i want to make sure they look as good as yours.;)
Thanks rob glad people are interested and its of people's taste.
I just searched for red led on ebay but this is the item
Number 151680106441.
Ordered gauges for pillar pod this week so sometime after 19th when the pod is available they will be going in too!
I am very interested. Got a red lcr on a 54plate. Got ocd with cleaning and keeping it swirl free and your car reminds me of mine with how clean it is. Mine is running stage 2. I will be ordering the interior lights because they do really make the interior. Keep up the great work bud. The car is a credit to you.:clap:
Thanks.
Just realised I hadn't posted up any pictures of the fitted trackslag.
The charge pipe is direct from trackslag from their website.
So much better build quality and look to the oem and the forge one I was running. Bigger diameter by half an inch, better bend with no dink underneath near the rocker cover and the bend continues almost to the turbo rather than using the silicone elbows.
No difference in sound over the forge one but over oem yes, can hear spool up more I found.
I will take a look at their website, at the moment my charge pipe is original and baffled so hopefully worth while , thanks for the info
Cheers James. Got issues today. Fault code 17608 so some boost related DV problem that needs sorting.
All sorted. The vacuum hoses from the Fpr and the DV had totally perished. The hoses must have been poor quality as the heat has destroyed them.
Did fit my Cookbot manifold/turbo heat shield today.
Yes pretty much sits around the lower jubilee clip area just off the top of the turbo. Really good fit.
Was it easy to fit Dan? Fitted my trackslag yesterday and it was a bit tight
What the heat shield? Yes piece of cake mate. Slid it in under the charge pipe and bolted it on
These are next on the list to be fitted.
R spec boost guage and oil pressure gauge.
Just waiting on a nomad double pod to become available then will look to get them fitted in the next couple of weeks!
So I have been busy today. Started off by tidying up the n249 and pipe work I had tucked at the back of the engine bay.
De cluttered it and then plugged it back in out the way.
