Tomoose_86
Hi,
I have a 52 plate Leon cupra 1.8 20v T and the amber engine warning light has come on. When its is started from stone cold it coughs and splutters into life, fine if I keep it revving at about 2,000rpm for about 30 seconds and once warmed up a bit idols fine. Also fine if I turn the engine off and back on once warmed up a bit.
I have taken it to seat main dealer (Nottingham) and they deleted the error code with diagnostics and said just see how it goes, the light came back on the next day!
I then took it to my local garage for ease and save cost as they didn't charge me. They put it on diagnostics again, deleted the error code and suggested to take off the pipercross induction kit I had on to see if that was upsetting a sensor somewhere. But came back on the next day again.
I don't think these will be related but I also have a problem with my temperature gauge because it doesn't warm upto 90 and stay there like it should. Ive had the water pump change so I'm guessing its a sensor of some sort somewhere.
My local garage gave me the error codes it was coming up with on the diagnostics which are:-
P1290 - Cooling system failure
P0171 - system too lean bank 1
I have a cat back stainless exhaust on it too in case this makes any difference.
Does anyone have any tips or ideas for the next step to sort these problems out?
Thanks,
Tom
Thanks,
Tom
