dash remove?
turbin
just got a new alpine head unit and it has this kool feature where I can use my phone via bluetooth to call and whatnot, anyways I need to run the mic wire from headunit to a-pillar... any easy way to do this?
also, I walked over an Golf R32 yesterday.. surprised how easy that was... are they really over rated ?
russman68
146
Surrey
I just did this for my becker grand prix mic. I just poked the cable through a hole at the bottom right of the HU case and taped it just under the steering wheel then run it up behind the a pillar.. just use electrical tape as you cant see it!
Oh and if it was a mkV it wasnt being driven properly! not the fastet when moving but good grip. You in a std LCR? - just saw your sig.. i just keep up with my mates mkIV in the twistys in a std LCR
turbin
right... I guess I could do that... altho, id prefer to get it done right... I got me long feet so it'll probably come loose and disturb me when I least need that..
No, it was the new version... dunno what MK it was.. max 2 years old. Mine is remapped and I could not believe the difference between us... not even close.
Aug 7, 2009
1,395
Manchester U.K
Do like russman said, a professional wouldent take the dash out lol, its a time consuming job and u will find it difficult to do probably and end up loosing somthing etc. Without looking i cant say buy try to follow a wire thats allready under there its possible and good luck if you take t he dashboard out lol
heatfan8
Insert witty comment here
Dec 2, 2008
368
Berkshire
Mine had a hands free kit. The wire got poked along behind the glovebox and up the a pillar - You can poke it inbetween the a pillar and the trim piece that overlaps it. Then it was poked up between the windscreen and headlining and dropped down alongside the interior light. Simples.
turbin
right... I found two hex bolts under the streering wheel but the plastic still wouldent move any. Probably taking the easy way out. Off to buy some black tape I am.
