Hi All
My missus was driving to work in her Leon TDi SE ('01) on Thursday when the coolant temp light flashed along with one other dashboard light, but the car kept running fine and the lights went out within 2 seconds. First thoughts were that the Tesco's fuel problem had also found itself into diesel cars!
Anyway, the car was OK coming home that evening but yesterday on the way to work the whole dash cut out, all the dials went to zero and the back illumination went out, the only things working were the odo / clock LCD screens, and the indicator lights on the console. It then kicked back in after a few minutes and worked for the rest of the journey, but on the way home it did the same and didnt work again all the way home.
This morning the dash is sort-of working again (fuel level showing nearly empty when its in fact full) so I plugged in VAG COM and got the following error codes from an auto scan:
Also what was odd is that the first time I turned the ignition on, the radiator fans switched themselves on despite the engine being stone cold and not switched on. That also hints towards an earthing problem on the coolant temperature sender, but not sure why that alone would make the dash cut out so I think its probably more widespread than that. Any ideas where to start looking
cheers
Chris
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 06441
1 Fault Found:
01297 - Sensor for Vent Temperature: Footwell (G192)
30-00 - Open or Short to B+
Address 17 -------------------------------------------------------
Controller: 1M0 920 901 B
Component: S5-KOMBIINSTR. VDO V03
Coding: 05422
Shop #: WSC 06441
IMMO-IDENTNR: SEZ7Z0Y0871446
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
29-10 - Short to Ground - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
cheers
Chris
