Evening! Today I started fitting the intercooler as seen earlier in the thread
Lots and lots of pics taken woo. Fitting was so easy, everything fits perfect and I only had to remove a few bits of plastic cowling with the grinder. No alterations to the crash bar either which is ideal!
I didn't completely get it done due to a
problem further down but it's being sorted
Anyway...
This is becoming such a classic position of my car in my drive now hahaha. Started removing the bumper bit by bit
With the trims removed the rubbish, leaky, tiny smic can be seen
The pipes are caked in oil, and leak like mad.
I then removed the whole smic and pipework
mmm tasty
Pics of the bumper on the floor with the pipework
The new smic having a little sleep in the cardboard box in the background
Check out the size difference!
I then started fitting the brackets to see where they go on the car, they are made to fit in where the radiator is held in place, no drilling required, woo!
I then started removing the crash bar for fitment
Brackets for the intercooler in place!!
This is the bit of plastic I said I had to cut, it's basically a bit of trim. Nothing too important.
And wala!!
Crash bar back on!
Now to start with the piping! It looked like it might be a pita to get all right but I just went onto the website where they show it all connected and I just followed that.
Cinnamon bagel and coffee required!
Made an absolute mess of the driveway though.
Pic showing the pipework connected
I used my seals from the old intercooler as they look to be in good condition but may fit new ones at a later date if required.
Removing the old MAP sensor to go into the new pipe.
I then had to leave it at that for the day because of a
problem shown below.
The kit was supposed to come with a MAP sensor reducer however they'd forgotten to put it in the box
Not to worry, just delayed a bit.
As you can see the hole is way too big for my map sensor
And as seen in the bottom left (although this is forge not airtech), the reducer was supposed to be in the kit but it wasn't.
The wait is killing me already, anyway thats all for now
I'd recommend this kit already, the pipework quality is excellent as is the cooler, brackets are perfect fitting too.
Cheers!
