D Badging
osorabjee
The time has come to get some of the 3 badges off the back of the ibiza...whats the best way to do this in a clean manor and avoid leaving marks?
Ruski
Very Very carefully with a small flat head screwdriver, thin towel and prise them off, then use some warm water and sponge and clean up. Always used to work for me.
osorabjee
Someone sugested i use a hairdryer to heat up the badge and slowly prise it off that way?
My only concern is there will be the remnance and outline of the letters left on the car! Did this happen with you?
reedbradshaw
Spireite till i die
Oct 6, 2006
199
chesterfield
i used hair dryer, pulled letters off
heated up glue on car - scraqped off with a screwdriver wrapped in a tea towl
then i just polished it all off
sorted !
osorabjee
just done it between rain showers...car looks PHAT!
Cheers guys!
air121005
1,609
Worcestershire
if your going to use a screwdriver to prise them off, i'd wrap some masking / insulation tape around the end, you have only got to slip and it gets expensive!
