Custom fmic
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
Now this is for my leon cupra just in case dpj says it has nothing to do with leons :lol:
i have the chance of getting one fully custom made and was wondering what peoples thoughts are on this??
i have the pro alloy one but after speaking to mitchy there will be a bit of pressure drop between the 2 outlets and it is a huge thing which does the job but maybe after something with a bit less of a pressure drop.
so would it be better single pass or twin pass?
slimmer or fatter?
smaller as in height or bigger in height?
and outlets kep to 70mm i presume>?
this is for a leon cupra not the R
cheers
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
single pas (like pro alloy and forge R) will be better
the pro alloy one is HUGE, a single pass in about the size of the current forge LC FMIC would be about right
i always learnt from my jap cars that too big an FMIC is a bad thing..which is what your saying regards pressure drops.
Could you not get a forge/allard etc universal and attach it to your existing Pro A pipework?
Wilko
Badge snob
You want as big an internal flow area as you can possibly get. Unless you have a tiny turbo, it is almost impossible to get too big an intercooler on a modern car. There just isn't enough room.
Single pass, with well designed end tanks. Your better off to loose a bit of runner length to get some bigger more progressively tapered end tanks. Most of the cooling is done in the first third of the runner, as the delta T and therefore heat transfer is greater.
Depth will always have more effect on internal cross section (flow area) than height. Adding 30% to depth has the same effect as adding 30% to height and is much more doable (usually)
The MoffMeister
Apr 4, 2006
2,937
colchester
haha is willingly yes but it'll be worth it when the car is how i want it and as for saving money may have to start another thread where i can spend some :lol:
