Cupra TDi performance mod
Jan 28, 2009
703
Glasgow
I bought a TDi mod which arrived for my cupra today, fitted it in and definately noticed a difference. I'm getting alot more power low end and my mpg has improved quite a bit too ...i know alot of you guys dont particularly think its a good idea or a good buy,but just wanted to ask y?? A remap will be going on soon but this seems good for the time-being. It sems to have boosted bhp/torque/mpg...any comments??
bobmcgod
323
You do know there are some sctual tuning boxes out there that are just as good as remap and arn't just resisters in a box?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
The TDUK red box and green box are very well thought of on the Vauxhall forum. the 1.9 150 CDTI engine goes from 150 to 200 with a green box :D
Maybe it's due to the Vauxhall 1.9 being common rail and 16 valve :think:
703
Glasgow
I'll be doing a few performance tests at my mates garage which should give me a rough indication on whether or not it's working....
Jan 28, 2009
703
Glasgow
i'll take a pic of the connection etc and post it up soon so you can have a better look at it..have to say though, took it out for a hard run today (dry roads :)) and it seems to have alot more power bottom end
Mr Cellotape
AKA Mr Ribbed
May 9, 2006
1,283
Warwickshire once.
I still can't figure out what you have done.
Was it a resistor box?
If it was anything adding any real power your gonna need a new clutch on the TDI Cupra.
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
The only thing they can do is alter the readings sensors give to the ECU, and a resistor is the most basic way to do this. So they can't be as good as a remap as a remap does so much more. And if a 'tuning box' was as good as a remap, why would people bother with remaps?
bobmcgod
323
Because of the reasons you just condem them all to hell with out trying them. The fake ones that are just resistors in a box.
And what does a remap do? Change the very basic settings of the engines computer. Take the normal sensor readings and change the calculation. Tuning boxes, the real ones, take the sensor readings run them through a calculation, then send back different readings to have the same effect as remaping an ecu.
Danneh
I very much beg to differ one of those 'things' from fleabay would add 25hp, or so they say.
sssstew
Editing your spelling
What i was getting at was the boxes only connect into the fuel temp sensor so hence can only make them chuck more fuel in. A remap increases boost a little to compensate for the more fuel going in leading to a better result.
Danneh
9Bhp increase I read.
I've seen many remaps do, much more.
I'd do a remap instead. This chip would only increase things such as economy by a maximum of a few mpg - You want to drive it harder to feel the increased power anyway, so it'll actually drop by, 1or 2mpg on your spirited run.
I just think if your going to do it, do it properly. Hence why I haven't done anything to my old, or new car because I would want to do it properly.
Nath.
Jan 1, 2006
8,620
16
^^^^^^^^^^^As said, nobody on the Astra forum bothers with a remap, They all use the TDUK red box or green box
They say the 1.9CDTI 150 with a green box will keep up with a VXR :yes:
Also there is a factory tuned Astra 1.9CDTI called an "888" these come from the factory with a green box fitted and the official spec is 197 BHP.
I have no idea what's inside a green box but They cost over £300 and they work a treat :whistle: Just don't tell my fleet manager cos she won't be very happy.
