yup, i had squeaking on my drivers seat. used silicone spray on it with the seat at the highest setting and set it back down. never squeaked again.
also had to put tape around the latch where the rear seats latch onto. This also made a rattling sound
now im having to clean and somewhat lube up my door seals and they make a noise when reversing. Its not alot of work though.
^^This. Check the rear seat latches
Had this on VW‘s before. Free play in rear seat latches seems to be a common source of unwanted interior noises in VAG cars. Electrical insulation tape around the seat latch is a quick, easy and cheap fix and if the rear seat back is regularly raised and lowered and the tape wears though, it takes just a couple of minutes to fit a new replacement piece of tape.
@JONNYVT - the originating source(s) of unwanted noises in a car’s interior can be quite deceptive. Quite a few owners on VW Golf forums have had what they thought were vibration / buzzing noises from the passenger side of the dashboard, when the actual noise source has been either the overhead mounted sunglasses compartment near the rear view mirror or the sliding cover for the vanity mirror in the passenger sun visor vibrating against the roof lining mounted vanity mirror light. With this in mind, I’ve found it’s always a good idea to have another person in the car who can
help locate the source of the unwanted noise(s) - e.g. they can apply pressure to trim pieces in the car in the area(s) where the noise is thought to be coming from while you’re driving. It’s very difficult - if not impossible - to do this by yourself while driving, especially if the unwanted noise is thought to originate from somewhere in the rear of the car.
