Cupra r suspension
Manic172
Dec 4, 2018
1,351
1,410
Hemel hempstead
www.seatcupra.net
I seen that all suspension parts be I g shocks. Antiroll bars lower arms etc all say for the cupra r or not. What is the difference between a "R" suspension and a normal leon
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
The anti roll bars ,front shockers and lower arms are all different on the cupra r
The anti roll bar if I remember right sits in a different place as the drop links go from the anti roll bar up to the front shocker
The lower arms are a cast steel
The normal Leon has a lower arm where the anti roll bar drop links bolts into it
Reactions: Manic172
Yellow fr
Sep 6, 2018
1,547
1,062
Leon arm
Cupra r arm
Reactions: Manic172
Manic172
Dec 4, 2018
1,351
1,410
Hemel hempstead
www.seatcupra.net
I have some "r" lower arms to fit. But am going to fit black pollybush to them first. Main reason is as I am going to be ordering my suspension struts soon . Going for AST with coil overs on the rear I want to make sure I get all the right set up.
Then it's going to have whiteline anti roll bars front and rear.
I been told that the "r" set up is the same as a 2wd audi??
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Whiteline do, do them for the R.
Eibach do a version for the TT which is a direct fit. Has adjustable front.
Badger5 Custom Map + TIP,
Reactions: Manic172
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,240
1,096
Kent
That’s correct, however, I’m sure a member on here found a TT cast wishbone with the link point of a cupra
Yes some early TT cast arms came with a small nub which can be drilled and tapped to accept the stock ARB drop links rather than using the longer R / TT shock mounted type.
However these are quite difficult to source.
Sent from my SM-G960F using Tapatalk
Jun 24, 2019
I know this was a while back but could anyone direct me to the cheapest mk1 Leon cupra r front arms? Looking online, they all appear to be ‘not for cupra r’
Thanks!
sol_j
27
Bit of a late reply, but will LCR springs and shocks work on a standard Cupra? I’ve asked something similar before but wanted to double-check as I’m leaning towards OEM now because of the price difference. My car’s currently on JOM coilovers, but I’m after standard parts for more comfort over bumps.
Can I mix standard shocks with LCR springs, or would I need both LCR shocks and springs to keep it slightly lower than stock and closer to how it sits now?
Also, when looking at parts, I see some listed as "for vehicles without sports suspension, "'' Suspension: for vehicles with standard suspension'' and "Suspension: for vehicles without bad road version." Are these the ones I should avoid?
