Cupra R ABT issues
Jenko
81
71
I think for the next rolling round day we should make
a trip of it and go to ABT. I reckon we would all get some unbelievable figures . My APR stage 1 would be putting out at least 500bhp
Reactions: ray and Zer0
queen
~Nassia~
Nov 29, 2010
709
70
Athens, Greece
Guys, this is totally off topic, but I wanted to ask - does DSG map improve 0-100 times or not?
Actually if stock launch control rpm is set around peak torque getting a dsg tune that for example raises the rpm and gets you off max torque will be better for 0-100kph figures. Also if your car produces peak hp near the redline raising the shift points will make the car have a fatter power curve that'll make it faster.
Zer0
522
242
Bit off topic but does anyone know much faster launch control is 0-100 km/h (0-62 mph) than a normal launch on a Cupra ST 4drive?
Jenko
81
71
Well all the stats say the non ABT car does it in 4.9.
Mines not ABT anymore but is just APR stage 1 and the best time I’ve managed is.
Jenko
81
71
Wow, fantastic time. :) LC I take it?
Yeh with LC at 3750 rpm launch. The best 0-60mph time I’ve managed is 3.69, I think that extra 2 mph difference is between 2nd and 3rd haha
Reactions: Zer0
Jan 14, 2020
It depends on which temp sensor they are working from.
I'll order the ABT option on my next Cupra as long as it's under $NZ2k mainly because it carries a SEAT backed warranty. I'm not that keen on other systems unless I can get it custom mapped and that is starting to get expensive.
Besides, our climate doesn't regularly get hot enough to be a serious issue, and it certainly wouldn't in the UK. The only time I can think of is in heavy summer traffic, but you're unlikely to need 340 hp in that.
got to mid 30s in London last year
Reactions: Jenko
Slickric21
561
254
Norfolk
Just a little update here on my R ST ABT.
I decided against a dyno run this week and put the money towards a dragy.
Did my first ever launch (nearly messed it up, I released at about 2.5k rpm) and was pleasantly surprised with the results.
0-60 4.18sec
1/4 Mile 12.42secs
Definite room for improvement, it’s wet and I’ve got 3rd tank of fuel.
Considering Matt Watson at Carwow got 4.4 and 13.1 in his review I’d say he didn’t have the oil temp up to 90’c for full power !!!
Jenko
81
71
0-60 4.18sec
1/4 Mile 12.42secs
Thats some pretty good numbers. You probably said but I can’t remember, have you got any other mods?
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
Remember the dyno in question is the TUV one, not the ABT one. with 1,000,000 mph of arctic air from the ground breaking fans they use
Slickric21
561
254
Norfolk
:)))))) Yup that’s the one
Re launch control, is it better to have ESC fully off or just in ESC Sport mode ?
Also whilst foot is planted to the floor on brake to engage it, when you then press the accelerator down, at what point do you let off ??
I just let off as soon as my foot got to the floor on accelerator, it was circa 2.5k revs. Should I have let it build up higher ?
ray
590
191
You should let it reach the launch control limiter as when it hits that your turbo will still be spooling up, by letting off before your turbo hasn’t had enough chance to reach optimum psi.
Reactions: Slickric21
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
ESC off, CUPRA mode, foot to the floor, the LC will limit the revs to optimum to launch and then off brake and you’re away. I have a manual so correct me if wrong lol.
Jenko
81
71
I think it wouldn’t let you go above 4000 rpm. But makes a big difference if you launch it at that.
Jenko
81
71
It will let you do it with just the esc in sport, I didn’t notice any difference in times with it completely off with the ABT kit on.
Then like said gearbox in sport not drive (can be any driving mode). Foot flat to the floor on break foot flat to the floor on throttle. Let the revs build, hold revs for a second or so, so turbos working hard then release the break and off you go :). It will just hold at 4000 rpm if you keep both feet planted
Reactions: Zer0 and Slickric21
