Cupra holding revs/increasing revs when changing gear?
messer
287
When driving the car sometimes under load or heavy acceleration, when I change gear the revs sometimes increase by say 500rpm before dropping back. I have just replaced the DV for a forge one but still does it. Any ideas?
May 25, 2004
2,691
Newport, South Wales
this white switch. Make sure it is made when the pedal is at rest and that it is released when the pedal is pressed.
As you can see, mine is now glued in, the threads bugger quote easily with it being plastic
messer
287
nice one thanks will have a look. In that thread a guy talks about a small white nut on the throttle controller? Whats that is it the same thing?
Ta
A
messer
287
nice one cheers will have a look and see if it sorts it. Had a quick look before but couldnt see it, will have to look harder obviously!
