Hey folks!
A few weeks ago, I parked up at home, about 5 mins later, my alarm was going off... I turned it off via the remote sensor, minute later its back on again!
I tried pressing lock twice on the remote to stop the sensors, but still no joy.
Same happened two or three times before I had to go outside (it was 1am!) to check it was ok, I checked windows were up etc etc.
I then locked the door with the key twice, hoping it would stop, It did that time.
Since then, whenever i've parked at home, I always lock the car with key turning it twice.
But tonight, I parked in different place (quite close (literally right next to) to another car to the right of me) locked with key twice and the alarm was going off randomly again! If I turned it off it would just go back on again anytime from a few seconds later to a few mins later!
It's a problem I need to fix, If I could i'd just leave my car unlocked here for the night tonight, but I can't as the thing keeps autolocking after 30 seconds!
I can't disconnect the battery as it will probably still go off!
I've moved my car to another parking area and locked with key twice, so far it seems ok I just hope it stays like that but what could be causing this?
I can't keep worrying every time I park up that im gonna wake the neighbours!
Will VAG COM show anything to fix this? It's under warranty so I can get it to a dealers to check but it's difficult to make the time from work.
It's bizarre, because everywhere else I've parked I don't remember it ever going off, and i've used the keyfob to lock it (single press) etc!
For reference...The LED on the drivers door has NEVER flashed ever since I bought it... So I was going to ask them to check that out as it may have something to do with it?
Many thanks for any help in advance...
