Hi
Was starting to worry a bit today! Car got it's last service on Tuesday prior to the warranty running out and guess what? Out for a run with the family today and suddenly loud "crunching" / "grinding" noise which appeared to be coming from drivers side front. The garage had warned me that the power steering pump needed replacing (so they ordered one up) and did wonder if it was that. But on investigation it turned out to be a small piece of gravel stuck between the metal back plate and the brake caliper. You would not believe the noise this made!!! So panic over.
As an aside. I'm rather assuming that the power steering pump will still be sorted under warranty, as it was identified before it ran out, even if they can't sort the part and fix it before the 26th Feb (when the Seat 3 year warranty runs out)... Anyone any experience of this happening????
