JonR356
I fitted my cruise control at the weekend, but it doesn't seem to be working quite right - any advice on the issue and how to fix would be appreciated.
I've got the type of cruise stalk with the two buttons on the end (+ and -, or set and resume)
I can get the cruise to engage by getting up to speed and pressing/holding the + button. This also seems to resume when starting from a lower speed. When cruise is engaged, the + button works, adding speed.
But the - button doesn't appear to do anything, and when connected to vag com the ECU doesn't detect when this switch is pressed in the appropriate measuring block.
Does this indicate that the - button isn't wired correctly, and does anyone know which of the sets of wires relates to the - button?
