Hi!
Tried retrofitting cruise control kit from VW yesterday and everything is in but it doesn't work. When I run vag com I can see all the buttons being pressed, but the car will not go into cruise mode.
Secondly, prior to installing the wiring, when I held the revs at 2000rpm in neutral and pressed the brake at the same time, the ecu would cut the power and bring it down to idle speed - since I installed the wiring it no longer does this - is this normal?
Thirdly, when I check vag com it permanently has a 1 and 1 next to the f37 and f46 readings for the brake pedal in block 006. Normal? Thought it was a faulty brake switch so changed that this morning but no difference.
Finally, when I first set off after switching the engine on, it will completely cut the power for about 5 seconds shortly after moving off, and then carry on as normal.
All of this has happened since installing cruise, which in itself took me a long time. Only recently got the tdi, so suffice to say I'm bloody frustrated.
(ps this a 110 tdi MK1 leon)
