cruise control problems
andy262
i have a 54 (2004) seat altea and my cruise controlis not switching on its beeing intermittant at times, does anyone have any ideas:cry:
andy262
faulty cruise control
mxcupra just tryed your like out a thankyou .
carefully removed my switch and cleaned the contacts replaced then taken out for test drive works as advertised many thanks, with the poor quality of the switch as other people have comented on who now how long till the next time
robint
168
9
UK, Essex
Mine has been fine after a quick clean as per Klawit info - been just over 6 months since done and no sign of a return of any problems.
leighivn
DSG Sport-FR 170bhp
Nov 19, 2008
22
Kent
Cruise Control Cut out
Hi All,
Just had this cruise control issue with my Altea 2.0TDi DSG, working fine on way to work then suddenly stopped working at all.
Checked out this forum for answers found this thread- cleaned switch as per instruction Cruise control now works fine.
Many Thanks to one and all.:D
aerobaticant
Faulty light?
Hi,
My cruise control works but I get no light on the dash to say its turned on.
The dealer says that there is no light fitted. Is this normal?
('57 FR 2.0 TFSi)
aerobaticant
Is that "yes, it's normal for there to be no light fitted" or "yes, it's normal for the dealer to say there's no light fitted" ?
:shrug:
markirel
faster on 2-wheels
Apr 7, 2006
169
Midlands
IIRC the SE has the large MFD display as standard and on this there is a criuse light function. For us lesser beings (where we didn't specify the bluetooth option) we have the small MFD display that scrolls through instantaneous consumption, ave. consumtion, clock, trip... and on this there is no cruise light.
A2day
On the newer models, event without the dotmatrix screen you will have the Cruise Control light!
aerobaticant
As I don't have a working light does anyone know if it's possible to fit one?
I can see that there is a place for it in the instrument cluster.
klawit
ALTEA 1.4 TSI 4YOU (my2015)
Oct 13, 2005
477
10
Germany, Cologne-Area
1) Yes ... I know
2) Yes ... it's possible to fit an LED there (as you can tell by the space)
3) No ... it won't be a working light ...
as the circuit board (?) misses the connection, i.e. the small dot-matrix cluster isn't fully equipped when it comes to modelyears 2006-2008
(don't know about the newer models, but if A2day (hi pal :happy:) says so, I'll bet he's right, as he's always well informed.)
... at least, this is what I've learned from our german 5P-board.
greets .... Klaus
