Cruise control not working
adammccarthy
Recently bought a Seat Ibiza 1.6 Sport 2010, it has crusie control but when i turn it on notihng happens, no light on the dash board just does nothing. any ideas how to fix this?
DEAN0
Old Git
Feb 1, 2006
5,419
Preston - UK
How are you switching it on ?
First you need to switch it on with the slide switch on top of the left stalk.
This will not switch the light in the dash on.
Then when you are at your required speed you need to press the set button ( lower button on the end of the stalk )
Then you should see the light in the dash and the car should hold speed
DEAN0
Old Git
Feb 1, 2006
5,419
Preston - UK
Ive been switching it on exactly like that
Check the simple things first like -
Are your brake lights stuck on ? - would indicate a faulty brake switch and prevent cruise control being used.
Then unfortunately and to quote m0rk - Diagnostics scan required I'm afraid
miner69er
36
something else to throw into this...
Are your feet completely away from the clutch and brake pedals. the micro switches are so sensitive for the clutch that even touching the pedal with a feather switches off the cruise. Only found this out because the wife could never get the cruise to work whilst driving my Ibiza.:confused: When I looked, her foot was just about touching the clutch, moved her foot away and hey presto cruise worked fine.;)
