Crank sensor location?
Mar 18, 2011
583
Teesside
Cheers for that pal, getting a code something along lines of crank position sensor, incorrect angle or something along them lines.
sm_cupra
159
West London
Im sure thats the camshaft sensor that everyones mentioning under the timing belt cover. the crank sensor is under the knock sensons underneather the oil filter housing towards the flywheel side of the block.
Reactions: Mozboosted
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
crank sensor is to the right of the oil filter behind the front engine mount m8,
the cam sensor is described above...
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
make sure of the sensor befor you carry out any work, could be the cam chain or tensioner need replacing
SWANSWAY CUPRA Dealership
