Could 17911 - Load Signal from Alternator Term. DF: Implausible Signal drain battery
Joemadden1989
1 Fault Found:
P1503 - 35-10 - - - Intermittent
Readiness: N/A
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Could the first error cause a flat battery when driving? I've been having an issue with my car where randomly you'll go out and the battery will be dead. Could this be the cause?
Joe.
mgrays
371
18
Aberdeen
If alternator is not charging or intermittently charging .. then yes that would mean your battery is not being charged and so is flat when coming to restart car.
Fazertech
Seat Virgin
Jan 14, 2015
Norfolk
Battery or alternator?
You want to check the connections under front of gearbox, the wires break and the altenator doesn't charge until you rev to about 3000revs.
It's a common problem and an easy fix if you can solder.
google How to: Fix broken Load Signal cable from Alternator
good luck
Joemadden1989
Unfortunately the garage has had a look at the wiring and its not that. They suspect the alternator, does anyone know what sort of amperage the alternator should put out?
Joe
CurtisCov
I have the P1503 fault code on my 1.6 MK2 Leon
I also have the 00668 - Supply Voltage Terminal 30 fault
I put a volt meter across the battery on idle and it was 14.5 volts
I am beginning to suspect the battery but i have no clue.
My battery dies if the car is left with ignition on but no engine running for about 2mins
Any suggestions?
Curt
RUM4MO
8,054
1,100
South Scotland
Before you do any thing else, you need to measure the current in the earth lead with the ignition off and with the ignition on but engine not running - be careful with your meter on its highest current range and make sure it has that range protected by a fuse.
Edit:- one thing, is the cooling fan(s) running after the engine is switched off?
CurtisCov
hi, thanks for getting back to me.
could you please tell me where the earth strap is?
thanks
curt
RUM4MO
8,054
1,100
South Scotland
It is the big black lead that is connected to the -VE side of the battery.
Maybe take that car to a place that sells batteries and get them to check out that battery (with no obligation to buy a new one from them).
CurtisCov
Ok thank you, i'll check it at the weekend.
I thought about that, Halfords do it i think.
