breslb
Folks,
anyone out there had to replace the coolant temperature sensor on a cordoba 1.4 2001.A diagnostic report says it's working intermitent.Would anyone have any pics of where it is and a brief instruction of how to fit.Any help much appreciated.
It's to the right hand side of the block with a circlip holding it in place from above. lift the circlip out with a small flat bladed screwdriver (be careful to catch the bastid!) and the sensor will pull out with no hassle. Refittibg is the reverse. You should see an increase in mpg when it's sorted too!
