Coolant loss/ white smoke
Millwas
10
Hi guys.
Desperate for help or advice.
I own a 14 plate leon fr 2.0tdi 184bhp. Recently I’ve noticed once the engine is warm (90c) white smoke will intermittently ploom out the exhaust. If you turn the car off and on again it stops. The car is also loosing coolant over a period of time. (200mile round trip last weekend and it emptied)
I’m really struggling for answers and no one seems to know anything 🙃 I don’t want to pump £££££ into her however I’d be devastated to let her go.
Thanks for reading!
Ricky88
27
Are you getting milky looking engine oil?
Can you see bubbles in the coolant?
I would do a compression test and a block test (with the liquid that changes colour if combustion gasses are detected) to rule out a head gasket issue.
SteveGSXR600K1
601
200
If it's the EGR cooler you wont see any leaks. I'm pretty sure this causes white smoke. Lets hope it's not the head gasket.
Millwas
10
There is no milky residue anywhere within the oil car or the dipstick. I can there aren’t any bubbles in the header tank either. I’m going to double check with the garage later today to see if they performed a compression test on the vehicle when they had it last week. I know they did a pressure test and there were not leaks spotted at all. I’m sorry for the awful description of things.
Millwas
10
Spoken to the garage. They are very sure it’s not a head gasket issue as there is no smoke from cold, a compression test was completed and it’s all good. There is no milky residue anywhere or any leaks obvious.
I’ve seen in other cases about the heater matrix being blocked so I’m going to replace that as I have no heat in the cabin and have coolant loss (seen this in another thread)
also stupidly forgot to mention the car only smokes intermittently but once the car is warm. any suggestions welcome and I appreciate everyone who’s commented so far! Legendary group of people
Reactions: Ricky88
Ricky88
27
Good news that the head gasket is sound.
Keep us updated with how you get on.
SuperV8
1,819
900
The heater matrix cannot make the exhaust smoke, It can cause you to loose coolant, expelled out your header tank cap and can cause no heat out your vents - but this could also be due to air lock or low coolant.
My money would be on the EGR cooler - so it can internally leak coolant into your exhaust - which would cause white smoke which is the coolant evaporating and condensing.
Millwas
10
Just waiting for my heater matrix to arrive from the parts company and the garage should hopefully be able to fit it today. The main reason of going with this first is I know that’s broken anyway so start there to stop/slow the coolant issue. Interestingly I’ve had the dpf warning light come on yesterday morning. So the garage will take a look at that too
SuperV8
1,819
900
Make sure they flush the cooling system BEFORE fitting your new matrix.
EGR cooler is used during/post regens so maybe the issue is effecting the DPF?
SuperV8
1,819
900
Haha, :ROFLMAO:
Just in case it is the egr cooler - last time I checked I think they were quite an expensive part 😭. Finger crossed it not - but just giving you a heads up!
edit:
04L131512BQ is the EGR cooler part number - and not as expensive as I was remembering!!!:D
martin j.
1,997
894
Fife
If you're losing coolant will the "white smoke" not be steam as the coolant evaporates into the hot exhaust ? are you getting a coolant/anti freeze smell when the white 'stuff' is emitted?
Millwas
10
Hey guys! Just to let you all know had the heater matrix changed for a new one and touch wood since had no problems at all! Car is running fine with no issues what so ever!
mom another subject I changed my own pollen filter today as it was absolute grim. ( sorry small win for me!)
Reactions: adam davies
mykro
75
7
and how coolant get into combustion chamber and causes white smoke, if it was problem with heater matrix? dont get it.... somebody here says that if h.mtrx. is blocked, coolant will go out through safety hole in expansion tank not into combustion chamber...? @Millwas
Millwas
10
Not entirely sure what was happen with it, however I had the heater matrix replaced as it was blocked and ever since the issue has stopped. The car still uses a bit of oil and water every now and again but nothing major.
Reactions: Walone
