I have noticed that I am having to top up coolant and am now getting kind of worried about this.
I have only owned my 1.4 75ps for about a year now and about 7 months down the line, I notice coolant is about 1-2cm below the Min marker. So I topped it up keeping the 50/50 G12 coolant / distilled water mix.
Since then I have kept a close eye on the level when the car is completely cold. I have noticed that every 3 weeks it goes in between the max and min marker (so reduces a little). I accept that’s normal so don’t bother topping up. I have once or twice put a little bit more to put it back to max, but has gone down as time went by.
It has been now 3 months since it’s stayed in between min and max when the car is cold.
Checking it again today revealed it was again sitting below the minimum marker (about 1-2cms again). However it has NOT triggered the coolant low alarm and never has! - But when you look at the coolant level when hot it’s sitting in between MAX and MIN which is normal.
Any ideas as to what this may be?. There is no common signs of head gasket failure on the car, and have checked the pipes and radiator and they seem fine.
Someone mentioned changing the expansion tank cap – but mines seems to lock fine :S should I still do it?
I am completely lost on what to do and appreciate it if someone could help.
Thanks and apologys for such a long post!
