convinence pack > auto dimming mirror > green light and what?
H8T WP
I have the auto dimming mirror, the button underneath switches it on and off.. when its on the green light on the left comes on, but what does the light on the right do / indicate ? or is it just for design? because i have never seen it illuminate etc
H8T WP
light sensor i thought was in same place as rain sensor? could be wrong tho
SEATcarsdirect.co.uk
The suto dimming mirror has a sensor on the inside aswell
Irfan
H8T WP
Irfan
so if i cover it with my hand the lights should come on? ill try later...
seems weird how the sensor is pointing inside the car and not detecting the outside light conditions?
If im right (so not 100% sure about this)
The sensor on the inside picks up when light shines on it and dim's the mirror
really usfull if you have someone with full beams on behind you
Irfan
H8T WP
I meant the sensor for light coming from behind. So that it knows when to dim;)
Ohhhhhhhhh i seeeeeeee , so therefore, if i shine a torch in it i should see it dim ! ;)
its weird how they made the sensor look like it could be a light.. o well i suppose this is all cleared up now :) cheers peeps
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
if i ever meet you i expect youll look something like this;
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
The mirror has 2 light sensors.
1 points forwards, 1 points backwards. If you feel up the back of the mirror, you will find the sensor. Cover this and the mirror should dim as there will be more light entering the other sensor (as there would be if you where being followed by someone with their headlights on)
I understand all that. Hope it makes sense.
SEATgod
The rain / light sensor attached to the windscreen has nothing to do with the dimming rear view mirror!!
Craig Senior is c0ck on!! :) - its the two light sensors inside the mirror that dicate if it is dimmed or not! One is on the back (facing the front of the car) and the other is the oblong lens that looks like a light. The control unit inside the mirror is a difference engine!
TTFN
Glovepup
Cupra Lova
May 27, 2006
450
Sevenoaks, Kent
Ok, but then we have switch to turn it on? The green light turns on i think when the button is pressed on the rearview. i dont understand why the button is required.
SEATgod
Because in certain conditions, like the sun setting behind you...you dont want the mirror to dip!
It works on light differences, if the light behind you is brighter than the light in front it will dip the mirror!
Besides...everyone likes having buttons to press!! ;-)
