comfort indicators??
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You tap the indicator and it flashes 3 times, saves putting the stalk down and ten up to cancel.
Should be fitted to BMW's they might use them more then ;)
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
thanks for the replys guys. the kit is an oem vw part that was fitted to some of the later cars. its very good quility as i have had it in my bora for ages and miss it now!! yes its really a true lazy mans toy!! i thing there is a link to the fitting inscuctions on the ebay link...
thanks lads!
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
they are fitted on the astras but get really anooying after a while, depends on the quality of the kit i suppose
yeah i had them in my vectra and believe me... if you ever see a vauxhall driving down the motorway alternating their indicators left, right, left, right, left, right, left, right, left, right, left, right, left, right, left, right... you get my point. ITS NOT THEIR FAULT!
the kit in the vags didnt make me want to hang myself... so they must be a bit better to live with!! i will absolutely be buying these!
oh and good shout on the instruction pdf richellis
speedinsaxo
528
I bought this and had a go at installing it but I could not get the pins out of the factory loom to place them in the new connector block. Might have another go when I have a spare afternoon. It's not difficult to do once you have the knack of getting the terminals out... I was temptet to cut and solder the wires, but didn't in case it did not work.
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Our Octy VRS (Mk2) has these - you can switch the indicators on as normal, or you can push the stalk to just short of locking into the up or down position to have the indicators flash 3 times and auto cancel. Not a whole lot of use to be honest, and not the same as the Vauxhall system which does not lock into the up or down position whilst indicating.
Dec 31, 2007
1,479
Reading
by the way lads - VW sell an add on unit for this that you plug straight into the CCM.
Let me check the p/n - someone pm'd it to me on Edition 38.
Dec 31, 2007
1,479
Reading
ah excuse me guys - as said above it does plug in just behind the hazard switch. Apparently the relay and loom is just under £30, but a bit fiddly.
p/n is 000998229A apparently
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
on the bora you had to pop out 3 or 4 terminals out of the hazzerd light switch plug and plug in some wires from the kiti
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Honestly, you guys would spend £45 on a thing that flashes your indicators 3 times for you.
Mental, you guys have too much money
Each to their own
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
When I awake bright and fresh each morn, I rub my eyes, note the time, then decide..... do I need the convenience and ease of comfort indicators ? Yes.... I take the VRS. If I feel that I won't be needing them today, I take the Leon.
Best of both worlds and it only cost £17k to have a 2nd car to enable such choice. Bargain.
:roflmao:
