coilovers or springs?
sparkyc
185
i realise coilovers would be a better choice, but are they that much better to warrant the extra money? dont wanna drop my LCR to much but wanna sort the handling!!
caveo
Get a decent set of springs and dampers if your not planning on going on the track , also stops the temptation to play.
sparkyc
185
cool cheers, will this not be a bit low though? speed bumps are a nightmare round my way!
sabredylan
Absolutely, you will never stop adjusting coilovers. springs are fine for road and your pocket.
daz_cymru
Leon Divotee
Jul 13, 2008
602
north wales
sorry for sounding like a n00b but what are the advantages for coilies over a matched spring/shock set....just the adjust ability?
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
50mm front and 30mm rear.
Damian @ DPM
Any special Credit Crunch Discounts coming soon? My creaking hot tuning coiloever are starting to really naff me off. !!!
Which comes to my next question, these weitecs, any noises or problems experianced by people?
smithygcupra
Cymru am Byth
May 25, 2008
271
Newport
technically you already have coilovers on the front.... it just means that the spring is over the damper/shock in one unit...hence coilovers!! .....
if you get springs/shocks that are the same rate as the coilovers the car will handle the same....
the only benefits are the adjusatbility with the coilovers and that you can usually go lower with coilys....
they look nice too....
unless your going to build an all out track car i dont really see the point.... IMO i dont see that they are worth all the extra £££.....
lots of people will argue otherwise... im just speaking from personal experience
GREY 225
Jim R
Oct 15, 2006
445
Ive got weitec and cant fault them,well made kit,they are actually part of kw so quality is good,they were about £100 cheaper than the kw mainly down to the kw having stainless steel legs and the weitec having just galvanised.Mine is lowered about 20mm and i havent had any problems at all,had wheels off the other day and the legs are spotless,no rust on dampers or springs and look as good as day they went on.
I havent adjusted mine since fitting and dont intend to but as it is it handles well,the ride is firm though and on some roads near me(yorkshire) it can sometimes feel a bit rough on the back roads but on a decent main road its spot on.:)
