coilovers and topmounts.. help please.
Jun 26, 2008
849
Sunderland
ok so im after coilovers, and ive decided im going for weitec HICON GTN's, just wondering if i need new top mounts and bearings or the original ones are ok to stick with. if i need them where do i get them from and roughly how much?
Cheers in advance.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Its worth replacing them mate, while your there.
There are part numbers, price and place to get them from in the Parts list thread, have a look in there.
Jun 26, 2008
849
Sunderland
Nice one mate, cheers.
By the way does anyone know how to disconnect the suspension strut from the topmount on the mk3. Do you have to undo the three bolts around the black plastic topmount cover as the cover doesn't seem to come off as it does on the mk2? :confused:
Thanks in advance.
Jun 26, 2008
849
Sunderland
Like this:
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I couldn't get the cover to come off either. In the end I jabbed a screwdriver through it and levered it out.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I pushed the black cover back on afterwards, with the hole of the screwdriver pointing backwards so you cant see it. I couldn't get the cover to sit back as it did though but good enough...
Jun 26, 2008
849
Sunderland
fair enough, i think i'll just do that then. bodge it :)
out of interest did you fit new top mount and bearings when you fitted coilovers or not?
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
i didnt bother but it is 'advised' to.
there is another little trick ... if you mash the plastic covers, look for the rubber boots that go over the rear suspension mounts in the boot..
these fit perfectly ;)
Jun 26, 2008
849
Sunderland
oh well i might as well then its not a hard job anyway tho so what can it hurt.
good plan! you got any idea where to get them from??
Plus what suspension you running now adam?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
uhm....currently have no topmounts on my coilies oops.
I apparantly have the front springs for the earlier version biza (mk2) which are much more narrow. That means the bearings are too big to fit on the metal 'discs' on top of the springs...
Atleast this is what I heard, but noone's been able to confirm.
Now am wondering if I can buy seperate wider top springs for the front coilies to sort this.
Edit: or possibly buy bearings which are more narrow to fit the current discs on top of the front coilies??
anyone? (by no means do I want to hogg your thread :) )
849
Sunderland
ha that sounds safe :whistle:
no problem. what coilies you got?
Adam R
Mar 5, 2007
2,851
lee in the solent
im running AP coilovers.
fantastic (i think). a bit rough at lower speeds but once you get going it becomes much more settled.
you can get the rubber boots from a dealer (stealer), a crashed ibiza (mk2's have these boots aswell).
Reuvers
you have mk2 springs which require a different top mount, i would try and change this asap as its not safe to be running like that
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Reuvers
so it is true...
guess I'll need the wider springs then and the discs to sit on top..hope I can find them somewhere sold seperately...
any of you seen this for sale anywhere by any chance?
cheers though adam
btw, its not making a difference in the drive to be honest. Its only 'clunking' quite a bit as the suspension is not moving on a smooth bearing when wheel is turned
Jun 26, 2008
849
Sunderland
spot on! Just ordered myself a set of Weitec HICON GTN coilovers and a full set of topmounts :D cant wait till they come! came to about £342 including delivery.
Plus i got sum pressed alloy plates from dubmeister with some nice german surrounds.
Chuffed! :funk:
